Reshaping NURBS curves
Tool
Tool set
Shortcut
Reshape
Basic
- (hyphen)
The Reshape tool can manipulate and reshape NURBS curves.
Mode
Description
Move Vertex
Changes the location of a vertex or several vertices
Add Vertex
Adds a vertex to the NURBS curve
Delete Vertex
Deletes a vertex from the NURBS curve
Change Vertex
Toggles an existing vertex between a corner vertex and smooth vertex
Working Plane Constrain
Moves the selected vertex or vertices on a working plane
X-axis constrain
Moves the selected vertex or vertices along the X axis
Y-axis constrain
Moves the selected vertex or vertices along the Y axis
Z-axis constrain
Moves the selected vertex or vertices along the Z axis
To reshape NURBS curves:
Select the NURBS curve to reshape. To reshape multiple vertices, the curve must be a single, smooth continuous NURBS curve.
Click the tool and the appropriate mode.
Select a vertex. When the cursor is over a vertex, the standard arrow cursor changes to an unfilled, four-way arrow.
Alternatively, to select several vertices at one time in Move Vertex mode, click with the Shift key pressed or click and drag to create a marquee around the desired vertices. Position the cursor over one of the vertices.
Reshape the NURBS curve.
In Move Vertex mode, click-drag the mouse to move the vertex or vertices. The selected constraint mode restricts the movement to the working plane or to one of the axes. Release the mouse at the desired location. Alternatively, enter the exact coordinates in the Data bar. Press the Tab key, enter the coordinates, and then press Enter.
To add a vertex in Add Vertex mode, move the cursor to an existing vertex near the location where the new vertex is to be added. The cursor becomes an arrow with two black diamonds when a vertex can be added. Drag the cursor to the desired location for the new vertex. Click at the new location.
To delete a vertex in Delete Vertex mode, click the vertex to delete.
Toggle the vertex between a corner vertex and a smooth vertex by clicking on the vertex in Change Vertex mode.
Functionality similar to the Reshape tool is available from the Object Info palette Shape tab; see Editing vertex-based objects.
Trazado de curvas NURBS
Reshaping objects
